Any suggestions please. Audio system was working perfectly then for some unknown reason it wont turn on. The power button turns green when the system is plugged in to the power but the display stays blank and nothing works at all in the system. It is driving me nuts and I would be eternally thankful for any ideas or suggestions.
Thank you
Billy
Hi there
This sounds like a hardware fault to be honest. You may need to consider contacting an authorised Sony repair centre.
http://services.sony.co.uk/support/en/repair/asc
