- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Chorus soundbar for sony KDL-50W705B
Hi all! Got my first soundbar for Christmas and have no clue how to set this up. I have an optical cable that i plug im but have no sound. Tried adjusting my tv settings but still no sound. Any help would be much appreciated
Thanks
Thomas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Do you have a make/model of your soundbar - might be useful, as then i can give you the best specific way of doing things.
Once connected to the TV, ensure that you set the TV Speakers to "Audio System" (or something similar).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Its the kitsound model
for sound options on my tv it only comes up as tv speakers and audio system which i tried before.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
On the TV you must set 'Speakers' to 'Audio System'
On the Kitsound Chorus soundbar, you need to set the input to 'Optical' - There is a button on the supplied remote control called 'Optical'
If that still fails, you will need to set 'Digital Audio Out' on the TV to 'PCM' (instead of Auto) - it is located in the sound settings of the TV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
No, that really is it... There are no other settings.
I can only suggest that you switch it all off, check that younhave fully plugged it in - the optical cable should 'click' into place. It can be a little stiff to do sometimes.
If everything still fails, i can only suggest trying it on another tv, to rule out a TV fault or request a replacement from the retailer it was purchased from.
