profile.country.CZ.title
Kuopching84
HT-MT500
Hi forum,
Recently I tried to upgrade my HT-MT500 with firmware M39.R.0377, but it fails everytime. I follow USB Update Instructions(https://www.sony.com/electronics/support/downloads/W0011352) . Everytime it ends up with message Update failed and  ERROR are displayed  on the display window. I tried to reset system to factory settings, but it didnt help either.
I also tried troubleshooting for the USB Update, but no results.
Please Can me get some advice!
Thanks in advance
My Setup:
Sony Device:HT-MT500
TV:SONY KD-75XE8596
Last known firmware M39.R.0106
4 REPLIES 4
Ho @Kuopching84, try to unzip the downloaded file with WinRAR if you have used another software. Then retry the update...
Kuopching84
Nope, It doesnt work. I try several tools for extracting archive( WinRAR,7-Zip,Windows 10 default tool) Result is always same=>Update failed. Any other suggestions please?
Have you tryed all troubleshootings at yours link?
Kuopching84
Yes, of course. As I wrote down in my first post, I tried everything listed here (https://www.sony.com/electronics/support/home-theater-sound-bars-home-theater-systems/ht-mt500/downl...) in section Troubleshooting for the USB Update.  Any help?
