Hi
My menu has started showing what appears to be Japanese writing on several menus and not all the graphics display correctly. I've tried a few factory resets which seems to have reduced the severity of the problem but not cured it.
Has anyone else come across this and if so, did you manage to solve and how?
Hi jaydubya76, thanks for your post. We're looking into this and will get back to you shortly.
Regards,
Pete_B
Hi @jaydubya76,
I recommend you get in touch with Support so they can assist you with this (details here). If you can send them a photo of the issue too, that would be helpful.
Cheers,
Cass
