Str dn1040 and samsung tv issue
pavloPL
I have amp and connected to my samsung f8500 tv but after reboot there is no image from sources, amp menu has green tint. Just cant use it with samsung tv. Anybody has a resolution. I have changed hdmi cable and is the same with others.
2 REPLIES 2
goshawn
I have the same issue - what I've found is I have to unplug the power on the TV, wait a few seconds, plug back in and the TV then performs the HDMI handshake again and things work.
I've tried powering on with different orders (TV, Reciever, Source) buit doesnt matter as periodically the TV will be blank. Only way to get it working again is to unplug the TV.
allinagain
Hi
From Sweden here.
The exact problem.
Have just bought the dn 1040 and want to run it with my Optoma HD70 projector and bluray LG BD550
and digital box from tv supplier.
That is.:
1 Hdmi out to projector. The other machines (bluray+digital box) Hdmi in to receiver marked BD and cabeltv.
No picture on display.
I want to use the Sony as a hdmi switch.
This should work according to Sony support in Sweden.
Well it dont and they dont help me with this.
Furthermore if I connect the projector directy to the bluray and uses coaxil cable for the sound it works.
So anyone have some ideas or do i have return the machine to the shop and buy something else.
