No signal audio notifications
garyp299
Исследователь
HI, have xperia L3, recently changed my audio settings while I was travelling. Now at home again have disabled every sound setting I can find but the damn thing keeps bleeping me to say I have no signal, we live in a low signal area which is not a problem. It only started doing this after I changed the audio settings now I cant get back to where I was before. Please help or it may end in in the Trent.
7 ОТВЕТ 7
Anonymous
Неприменимо
Hi there,
Can you clarify more about the audio settings that you have changed to be able to help ?
garyp299
Исследователь
Sorry, if I knew that I could probably proceed. Simply I have now turned off everything I can find,set total silence, even managed to turn off notifications, still as I listen to music and move around the house volume goes down, beep beep, guess what, you have no signal. I need to know the specific location to turn this off(if there is one).
I suspect that during the last software update some bored software engineer decided it might be fun to kill this option.
Regards
profile.country.NL.title
Strampke
Try this:
In developer options find Mobile data always active and switch it off.
Don't know if that's the setting needed, worth a try.
garyp299
Исследователь
HI, thanks for response, don't appear to have developer options under my system heading. (android 8:1:0).
Gary
Strampke
Settings -> system -> tap on about phone several times and developer options will appear
garyp299
Исследователь
Have tried tapping "about phone" multiple times but always get the same page which doesn't contain developer options. Have now got round problem by putting phone in holster rather than pocket so signal stays up. Thanks for your help. Gary
Piscie
you can also check this link for more tips about improving the signal. :slight_smile:
