"Own order" rearrangement problem in jb 4.2
Puspak
There is a problem in own order arrangement. Whenever I arrange my apps accordingly, phone rearranges apps in its default order after I restart the phone.....
please help, how to overcome the problem
Ashoksc19
Contributor
Move your all apps into phone memory
Setting-Apps-Internal and move each apps into phone(Move to Phone)
5 REPLIES 5
Ashoksc19
Contributor
Puspak
thanks for ur reply, it worked. BT has there any other solution? because my phone is full of apps,if I move all the apps to the phone memory, then the phone memory will be out of space.....luking for your reply and thanks in advance.
Ashoksc19
Contributor
Glad to hear that! But There's no other solution if you don't want to rearrangment apps just keep your internal memory apps at last window pane.
I didn't face in previous version. It's probably a bug.
Puspak
yes may be.....do u hv any idea that Sony will fix the bug or not???????
I dnt know as I am new to Sony......
SenJacob
We can't install all app in just 1.5GB phone memory. Nowadays even a single game takes 1GB. Please fix the bug soon.
