mnky75
4od not working
I have upgraded my Xperia M2 to Kitkat 4.4.2. and I noticed that my 4od app was missing.  I tried to reinstall it from Google Play only to be told that my phone is not compatible.
I'm not sure if it is a problem with Channel 4 or with Sony, 4od worked prior to upgrading and was my go-to app for my 2 hour commute.  I just wanted to see if anyone else has had this problem.:smileysad:
mnky75
Thanks mate, I'll try this tonight!!:smileyhappy:
2 REPLIES 2
Thommo
Just downloaded this on to my M2 running 4.4.2 without issue so what I've done is create a backup of the app which you can download from here and then transfer to your phone for what's known as sideloading
mnky75
