Battery doesn't last
Sol12
I bought this product two days ago and it's disappointing. Battery lasts from 12pm to 10pm even though I have not used it. I just charged til 100% and leave it at home since I didn't have service yet. When I got back, it was 15%. There wasn't any app running and at the moment I start using it, that 15% only lasted for 10 minutes. Wasn't it supposed to last up two days using ultra stamina mode?
1 REPLY 1
trapsuutjies
Hi! I've had lots of battery issues as well, which is annoying because the 'lasts 2 days' advertising was part of the reason I bought this phone. I've found that the location feature is the biggest battery drain, so if any application uses location it'll drain your battery within hours. Switch it to battery saving mode, and uninstall any location-using apps that you don't need - then you can go a whole day without charge. In Ultra stamina mode I usually get at least 5 days on a full charge, if you don't then I guess there's something wrong with your battery.
