Battery Drainage
Milan_
Battery Drainage
Hey Guys my batter is draining very fast in V1904... I have factorg resented 3 times still it's not working. I m from India I have not updated my phone still to 4.3... What should I do?? R
11 REPLIES 11
Milan_
Milan_ Advicer
Apr 7
I had done charging for 4 hrs when battery was40% but then also no improvement is there instead its draining... I wanted to know that whether i should charge my phone 4-5 hours when battery completely drains and switches off ???? And should i charge it regularly or what ???? And also after using it in safe mode not much improvement is there ???? And also it really works or what after charging it till 5 hrs
Xandy85
Hello Sony!:smileyrainbow:
The dual version ftf of 4.3 it's best for my single M...
All problems have been solved by flashing my M with this one...
Thank you Sony!
Good luck and keep your higher standards and lower prices!
God bless You!
Alexander!:smileyrainbow:
