com.sonymobile.china.photoeditor
alexanderive
Hello, I saw that about a week ago when I want to set a wallpaper and ask me for crop aplication, there is a com.sonymobile.china.photoeditor app. Is this a virus?
Uliwooly
just download apps from the playstore and check the app permissions before installing them.
21 REPLIES 21
Thommo
Where in the world are you and where in your phone did you see this?
Phy
Legend
Legend
alexanderive
I am from Romania, so excuse me for my english :).
When I want to set a wallpaper it is asking me wich app I want to use. The steps are:
Use as/wallpaper (album or google+, I choose album)/complete action using ...
Here is the app I am asking. I have to choose between Crop photo, crop picture (com.sonymobile.photoeditor) and crop picture (com.sonymobile.china.photoeditor).
I had disabled the app from the app manager but I dont know if it is not a virus.
Uliwooly
Follow @Phy suggestion, if you don't get that option while on safe mode then its a third party app, btw is your phone from China?
alexanderive
No is from Orange Romania.
Uliwooly
Do you get both options while on safemode?
alexanderive
No. There is a diference in what I had said. The china option is sonymobile and the other is sonyericsson.
In safe mode is like a few days ago with only two optioms google+ and crop picture. I dont know how to atach printscreens to show you the diference. Thank you for your patience and help.
alexanderive
Ichave.to say I protect my phone with Avast
Uliwooly
Then that show its an app that you installed either through the play store or if you sideloaded an app, you can uninstall apps or just repair your phone with PCC, I would do do that (repair my phone with PCC)
