Mr525
failed to update
My phone not update over wifi. Here is problem. It could download 100% error in install. There message appears "could not install".
Mr525
Sorry the message appears at my phone is not "aceess code change". That is "restricted access changed" what is does it means?
11 REPLIES 11
Uliwooly
Are you trying to update the phone or an app?
Mr525
Trying to update my phone
Uliwooly
That's rather odd, you might want to use PCC
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
Mr525
I have another problem in my smart phone.. There is message always appear in my cell phone screen "aceess code change". What does it means?
Uliwooly
Access code change? could you poste a screenshot? it could be a network alert.
Mr525
Uliwooly
Do you have an antivirus app? that could be the issue.
Mr525
That message appears from first day when i first switch on my mobile...
Uliwooly
Again that's probably your SIM card or something else, it will be helpful if you take a screenshot and post it here, but you could just repair your phone with PCC and check again
