how to disable encryption
raider
I have encrypted my phone and now I want to set a normal swipe lock but I cannot enable it. How do I disable the encryption?
Uliwooly
You will have to reformat your phone with PCC
12 REPLIES 12
Uliwooly
Uliwooly
raider
Supposed if I have switched off my mobile and a person robs it. So when.he will switch on the phone will he be able to use the phone or he can factory rest the mobile without entering password?
Hampus
Champion
That person can still perform this software repair that
raider
Sony should do something about this! 😕
Uliwooly
You could use MyXperia or Android device manager to lock your phone.
kashmira
What is the password for error dycrpt to storage password for xperia M plz help
Uliwooly
@kashmira were you able to solve your issue?
iSaidyiu
How exactly is to "reformat" the phone? I only found an option called Software Repair and in the past this option just reflash the firmware but nothing else...
I have tried reflashing the .FTF using another software but still encryption is still there and this critically slow down the performance of the device, so I really wish to decrypt it...
