How to insert sim
Asbid
How to insert sim
Plz tell me how to put in and put out sim in Xperia m2
Is that like sd card or sim jacket come out
12 REPLIES 12
Uliwooly
@Tilly2017
Did you checked the above suggestions? have you tested a different SIM card?
Misterfied
My XperiaM4 Aqua is unresponsive, attempts to turn it on result in a white screen with the Sony text logo. from that point on it does nothing. I attempted to remove the SIM card and MicroSD card , have re-inserted the SIM card with the same negative results. Is there a Do It Yourself fix ?
To complicate matters, the problem seems to be the result of my attempt to re-install the system as the Xperia Companion was not recognizing the phone. A system program download also failed, when I tried to use it to repair the phone's system which brought on the white screen problem. Ferom that point on, I am stymied and unable to get the adroid system up and running . Please advise?
profile.country.US.title
bloxstrap5
On the Xperia M2 the SIM card doesn’t slide out like an SD card tray.
  • First, power off your phone.
  • On the left-hand side, you’ll see a small flap/cover. Open it.
  • Under the cover you’ll find slots for both the micro SIM and microSD card.
  • To insert: gently push your SIM card into the SIM slot until it clicks into place.
  • To remove: carefully push it in a little with your fingernail or a small tool; it should release and slide out.
It’s not a removable “SIM jacket/tray” like on newer phones—it’s more like a direct slot under the flap.
