tadejkoball
Running slow
Hello!
Each day my phone starts running slow for about 10 - 15 minutes. After that, I have to reboot my phone to work normaly again.
I have a lot of apps, but I think this isn't normal.Do you think that downgrade to 4.1.2 would help?
Thanks.
Tags (4)
Uliwooly
If that doesn't help, then repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
6 REPLIES 6
Uliwooly
Its probably bc of apps running on the background using up your RAM, perhaps antivirus, ram apps, taskillers, etc
Uliwooly
Boot on safe mode and see if that helps
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
if it does then its a third party app causing this issue.
Uliwooly
PC Companion (PCC)
Bridge (for Mac)
Hampus
Champion
You can also take a look at the following FAQ-topic to see if you can find any tips:
/t5/FAQ/Does-your-phone-feel-slow-and-laggy/m-p/347824
tadejkoball
Thanks, It works fine now.
Uliwooly
@tadejkoball
I'm glad its working now
