vertical lines on screen
Sfiso
I've had the phone for two weeks now but it suddenly started having vertical lines on the screen, it's been on and off but now seems to be permanent. Please assist
13 REPLIES 13
Jushua
I am experiencing the same issue with my sony xa ultra. What could have caused this problem and how to fix this.
Ffs1
I also have this problem with my phone it started last night after I went out for a run. The lines come and go, is there some fault with the graphics on these phones?
AMRO-X
I have the same problem,
When i open my phone everything is ok ,but after 10 seconds white vertical lines appears
moorhunhe
I have the same problem.
Taking a screenshot is not possible. When you scroll, the lines stay where they are.
I turn my phone on and off numerous times, and then it seems gone.
Very visible on very light and very dark background.
This was too expensive to be failing after 6 months of purchase! Hasn't happened in a while, and now twice today.
I have the xperia x compact.
