When turning bluetooth on WiFi drops
rmahmud28
For some reason when I try to turn on Bluetooth the wifi becomes unstable, disconnects and reconnects. Any idea how to fix this issue or will it be fixed in the 15.4.A.1.10 update? Thanks.
rmahmud28
Fixed the problem by repairing software. Thanks anyway
1 REPLY 1
rmahmud28
