About Xperia TX (LT29i) Rooted
lpaulorlan
I have rooted xperia tx and i have the latest firmware version 4.1.2 JB 9.1.B.0.411
my problem is.... my phone xperia tx s still recieving the same firmware version 9.1.B.0.411 on Update Centre..
Can anyone please help me... Thankz
Nabeel
Master
Go to settings > apps > all > update center > clear data
If that notification appears again then let me know.
7 REPLIES 7
Nabeel
Master
lpaulorlan
but when my phone dies again,  and i open it again the firmware update still recieve.. and im doing it again what you said..
Nabeel
Master
Have you flashed any other kernel ?
lpaulorlan
im using CWM
Nabeel
Master
If you're still facing the problem then I suggest you go for a software repair using SUS and then again root your phone.
CWM is not the cause , it's probably something else.
attiya
i buy sony TX lt 29 i two days before ,, but its mobile data is not working ,is it some software problem ,or should i give it back to the seller or any other options ,,plzz tell
Anker
I have sony xperia rx and it is rooted. Android version is ICS 4.0.4 .I can't update next version.
Then, I unrooted that Ph. But can't update after unrooted. How can I do to update my Ph.
Please help me !!!!!
