dear sir,
i have andoid version 4.0.4 on my sony xperia tipo st2i but am still unable to install bbm application from the android market.the msg runs "this item isnt compatible with your device" and the minimum requirement for the application is android 4 and above.Hoping for a reply at the earliest.
thankyou
hey someone please tell me, after downloading the apk to PC, where to transfer it in the phone??
as in in which file should i transfer the apk in my phone? and then how to access it from my phone, please give a more detailed way till the end..plsss plss plss
just please tell me what to do after transfering bbm.apk to tipo, where to go in the phone in order to install bbm?
any of those for whom it worked, just please tell me how exactly it worked after following these steps???????
I can touch on install...why? HELP
bro check wedr ua net settings r on.... tryin it again n again...
i've downloaded the apk in my personal computer.. and when it comes to transferring it in my phone, i dont know where to transfer it and install the app from.. please reply ASAP. thankyou.
it worked it worked it workedddddd!
THANK YOUUUU SOO MCUH
