UPDATED TO REFLECT CHANGES NOTICED IN 6.2.B.1.96
This is an Bugs Review / Update / and comparison from what I could find in my experience with the Xperia Acro S on Ice Cream Sandwich and Jelly Bean.
For the record I recently updated mine from version 6.1.A.2.45 (4.0.4) to 6.2.B.0.200 (4.1.2)
But I keep my wife's Acro S on 6.1.A.2.55 to better contrast the difference and bugs... NOW WE ARE BOTH AT 6.2.B.1.96
Also, notice that changes made are at the end of each bullet point in color... Green meaning is fixed, orange somewhat not Sony's fault, does not apply as bug or a workaround is available, and red is trouble.
So this comparison will be focused on those Bugs, and I will also comment on the new features and the ones that were left out.
1) Camera / Album / Gallery
1.1) Error message of "Internal Memory Error".
SEEMS TO BE FIXED ON JB. BUT I HAVE YET TO TAKE LOTS OF PICTURES TO REPRODUCE ERROR AGAIN.
1.2) 3D Multi-angle pictures are saved twice.
THIS FEATURE SEEM TO BE REMOVE FOR THE JELLY BEAN UPDATE.
1.3) If I open a picture straight from the view finder, many times when I zoom in, it shows black squares as if there were patches missing from it.
THIS SEEMS TO BE FIXED
1.4) Sometimes when sliding to the next picture in Album or Zooming by double tap, the picture jumps outside of the screen area.
THIS WAS FIXED. NOW THE ALBUM IS SMOOTH AND RESPOND BETTER
1.5) Selecting a sharing option from Album should remember the application used to share. But every time I have to reopen the full list to find the app of my choice... (other phones keep the selection next to the 3-connected-dots sharing button) This phone resets that selection.
THIS WAS FIXED. THE MOST USED APP FOR SHARE GOES AT THE TOP.
1.6) While Quick Launch is an awesome feature, it does not work if I halfpress the shutter and then press completely... I have to press all the way quickly...
THIS WAS FIXED
2) Music
2.1) It is not common, but sometimes the music skips maybe due to load by other applications running.
HAS NOT HAPPENED AGAIN ON JB. GOOGLE CHROME TAKES HUGE CHUNKS OF RAM AND FORCE CLOSES OTHER APPS INCLUDING WALKMAN
2.2) Sometimes music does not resume once again after it was pause by apps such as received call, opening the camera.
THIS IS APP DEPENDENT AND IT ACTS BETTER. NOW WE CAN KEEP THE MUSIC PLAYING WHILE TAKING PICTURES EVEN IF THE SHUTTER SOUND IS ON.
2.3) Music interrupts when receiving a SMS, GTalk and while receiving instructions from Waze. But it works fine without interruption when receiving a Whatsapp message. This might be an Android problem unrelated to Sony's software.
THIS MIGHT BE AN ANDROID ISSUE.
3) Miscellaneous
3.1) Currently the Power Saver app resets its configuration after a phone reboot, so this makes it utterly unusable. This problem is found on other Xperia models.
THIS WAS REPLACED BY EXTENDED MODE. ASSUMED FIXED
3.2) Sometimes the Infinity view of contacts does not display all icons, specially when viewing a contact shortcut in Homescreen.
THIS WAS FIXED AND THE DESIGN IS DIFFERENT
3.3) This model is not able to display battery percentage natively, but the Xperia Advance can... And it is a native feature of ICS
FIXED
3.4) Lock Screen Wallpaper does not show, it only shows the same wallpaper chose on homescreen. No matter if I try to change it.
THIS IS STILL PRESENT. IF YOU HAVE SECURITY FOR YOUR PHONE SUCH AS FACE UNLOCK OR PATTERN LOCK IT WILL NOT DISPLAY A LOCK WALLPAPER NOR WILL HAVE THE MUSIC CONTROLS UNLESS MUSIC IS PLAYING.
3.5) By using a standard BT keyboard, there is a lack of key combinations, and when using arrows to select "Settings" from the notification bar, it is not able to do so. The only way to select "Settings" with a keyboard is from the App Drawer
NOW KEYBOARDS ARE NATIVELY SUPPORTED BUT THERE IS NO SUPPORT FOR WINDOWS KEY, F1-12, PRINT SCREEN... SO YOU BETTER GET AN ANDROID KEYBOARD INSTEAD. NOTIFICATION BAR IS SELECTABLE BY KEYBOARD, BUT RECENT APPS IS NOT.
3.6) Sometimes when getting a call, the slider is not responsive. The solution is to hit Power button off and on. This might be an Android problem.
THIS HAS NOT HAPPENED YET
3.7) There have been a couple of times when the Accelerometer is not responsive. And accessing to the Service Menu, it shows no values for X, Y and Z. Solution is to reboot phone.
POSSIBLE HARDWARE PROBLEM OF MY UNIT
3.8) Even though there is values changing in Service test for Ambient light sensor, I see LITTLE change when using the phone.
AMBIENT LIGHT SENSOR WORKS BUT IT DOES NOT CHANGE DRAMATICALLY SO IS DIFFICULT TO PERCEIVE...
3.9) Even though description and MENU shows WiFi Direct as a feature, there is no way to activate it. But the Xperia Go has it in connection settings... So we are stuck with slow transfers via Bluetooth...
NO WIFI DIRECT STILL... VERY DISAPPOINTING
3.10) Most Mouse I have tried have only left click functionality and scroll... and the right and middle click, makes the same left click. Logically it should allow for a "menu" click, and/or a "back" click...
STILL PRESENT... ALL BUTTONS ON THE MOUSE DO THE SAME LEFT CLICK FUNCTION
3.11) Now this is a minor complain, and probably hardware related... but touches near the edge of the screen are registered to the extreme edge... almost like forcing the touch to the edge... making difficult to select taps slightly separated from the edge.
THIS IS PRESENT. PROBABLY HARDWARE RELATED.
NOW THIS ARE IMPORTANT NEW FEATURES FOUND (SONY RELATED). AND ALSO LEFT OUT FROM PREVIOUS VERSION. AND FINALLY NEW BUGS
NEW
NOT ANYMORE
NEW BUGS
I hope this can be useful to Sony and other Xperia Acro S users...
Thanks
Diego.
One that didn't happen in previous firmwares than .96 (though it was reported by some users):
If you charge the phone when it's off, the green led remains on when you unplug the charger. I've left it for some minutes and it didn't turn off. Pressing the power button once, turns it off.
Does this happen to any of you?
I haven't had that problem... green led turns on while charging and turns off after being unplug...
just wanna ask if you recommend the JB since it's been updated late august. i have an acro s and i'm still running my ics and i'm scared to update it to jb because of the bugs.
Yes,you should update to JB,even though some complain about it.The phone performace improves a lot and you will enjoy many more features on JB.
Hi Krizsa, well the reason I made this comparisson was to help each owner of an Acro S to decide if the upgrade was worth it for them or not...
Like I said at the bottom, there are a couple of trade off when upgrading, most of them are really not important, such as the specific use of Mouse buttons or an external Keyboard shortcuts.... but there are some that are annoying in my opinion..
I loved the fact I could go through a long list in ICS by sliding 2 fingers across... This feature was removed so now you depend on the list scroller to the right (if the list have it, but no all do... see Settings > App... and scroll)
The other feature that was remove was 3D camera, specially Multi Angle effect, I think this was a truly unique one that makes a lot of WOW when I showed to other people... Sad to see it gone, specially since I still have a couple of those pictures in my gallery....
Finally the Recent Apps list used to be found by holding the Home Key... now it needs a double tap which is incredibly annoying, even after getting used to...
Remember that Video Recording was fix in the latest .96 update.... so no worries here...
And you will get a lot of goodies with Jelly Bean... Most notably:
Small Apps (under Recent Apps list, double tapping Home Key)
BT, WiFi, Data and Sound TOGGLES in the Notification Bar
Better way to arrange Home Screens and App Drawer
Expandable Notifications (specially useful for Walkman, Whatsapp, gmail)
And the Camera UI was truly improved...
I would definitely say Go For It.... if you are getting the latest update.
Good luck
thank you
i hope it goes well for me
thanks again!!!!!
When we can expect new update to fix wi-fi issue for Sony Xperia S ?
I got problems with wi-fi since 6.B.0.2.200, 211. was not able for me, and now im on 6.2.B.1.96 wi-fi not working !
Dont say to me: "try repair with PC Companion or SUS coz that dont work, i cant do repair with PC Comanion it got some bug always stuck on "prepare" proces".
Nils-Arvid:
2 weeks ago
The phone can drop the sound in the bluetooth headphones after 10 - 20 min conversation and you have to switch the sound to the speaker and then back to bluetooth again to resume the conversation.
This bug is also seen in Xperia V."
I think this bug is related to the one I mention when using HDMI.
The audio output gets routed to the headphone instead of keeping it through the TV.
It happens to me frequently and my solution is to unplug the HDMI cable and then plug it again.
This sounds very similar... since I think is an issue with the sound output control, the one that tells it should go through speaker, headphone, HDMI, jack...
Hopefully we receive a small update fixing this issue, because I confirmed it in both Acro S we have in the house.
