hello to everyone...!
my arc s is not charging when is turned off
i turn off the device,and when i plug it in the charger,it shows me sony logo, -same time blue led- and then nothing.
i dont see the thunder any more as i supposed to ... 😕
could you please help me.? sorry for my bad english
Oops, that might be a problem with the charger or something
How about using another charger in your phone ?
Also try to use your charger in other mobile to see if it works perfectly.
I am also facing Charging Issue with Sony Xperia arc S Lt 18i. I am looking for charger file which i need to replaced on system/bin file path. I have checked the below link but i did not find file on that link. Can any one help,me with "charger" file.
