Does the Mobile BRAVIA® Engine process the signal output via HDMI or just on the phone's Reality Display?
most probably just the phone's display, because its the ability of the phone's screen
good question...
i connect my phone on my bravia lcd , so never really thought of this :smileygrin:
i think the quality will be the same.. not sure though..
nabeelraza is correct, just via the screen sorry.
