How about Camera UI in WT19's ICS update??
TheNuarz
Hello , i want to know how about the camera ui in wt19 ICS update . Can we take a photo with front camera? or make a panorama and 3D picture like the GB. Thanks Slightly_smiling_Face
Tincho
Check this thread, And yes, there are some good news for you: Panorama and 3D Panorama made it to ICS!
5 REPLIES 5
Uliwooly
I wasn't aware that LWW could take 3D sweep panorama. you should keep the same features on the ICS update
Tincho
Yes, you can as of .62 firmware (on Gingerbread. I'm also interested on whether ICS keeps this feature). In fact, it even has a 3D Gallery app. You need a 3D compatible device to view the image, though. The phone only shows 3D panoramas as auto-scrolling images.
Uliwooly
that's great I thought that feature was only for the Arc, Play, Neo Neo V Dizzy_Face it's great that LWW has it too.
Tincho
@uliwooly: this is on Gingerbread. I hope ICS keeps this feature.
Tincho
