how can i make conference calls in my sonyericcsson live with walkman???my network provider already activated my conference call and my connection is an postpaid kindly please help me as soon as possible
Make a call first...
Then do another call, take dial and dial another number...
While you connect the second number the first will be on hold, check the hold button there will be an option for connecting the call... Same way you can connect more calls...
thanks dude got it :):)
Always welcome...
