In order for your device to be water resistant, the covers for the micro USB port, the micro SD card and the headset connector must be firmly closed. Also, make sure that the battery cover is attached correctly.
This is something that you can find in the user guide at page 131:
http://www-support-downloads.sonymobile.com/lt25i/userguide_EN_LT25i_3_Android4.1.pdf
With the two big yellow dots on the side I guess that you mean the connector for charging dock, there is no need to cover these in order to make the unit reach the IP-classification.
