I have updated my xperia u from gingerbird to ics.It look and feel good.I found it was slow when updated,but when reset it then it speed performance found same as with gingerbird.So speed and other look&feel fine with ics.
But there one thing that i have not found is screen capture.In gingerbird it was in long press of power key,but now it is miss from there.So plesae anyone can help is it possible now or not.If yes,so how can i capture screen shot.
Thanks
V.k.
Please use the search option
Press and hold power button and volume down button exactly at the same time and hold them there until you take a screenshot
Power + volume down for about 1.5 seconds.
Image is stored in /sdcard/Pictures/Screenshots.
Thanks Nabeel,
It worked for me....:)
Regard
Vk
wel where is the search option?
I also need the screen shot option
hello can u please tell me where is the search option i couldnt find it
No search option here.
You simply need to do this step:
Press and hold power button and volume down button exactly at the same time and hold them there until you take a screenshot.
vk
but its not working
I took just now two or three times.It is tuff to take screenshot but when you will take two or more time it will be easier.Just try out as mention above reply and sure you will take it.
At same time,first power button and with quick same time press -ve volume key(down key) and press it for that time till you not take shot.It may be take 1 to 2 sec.
thank u its done
