When a music is played, pressing the "back" button will push the player to background. How can I stop the that? in the support manual only it is tated how to push to background or delete the track!
just add the music widget somewhere in the homescreen or if you lock the screen and then turn it on slide the clock to the left it will reveal a music player.
if you have the headphones just press it once to stop/play music, twice to skip to the next song, thrice to go back to the previous track
ok. How about the phone itself. I have not plugged the headphone.
I think what you said, causes a "pause". Is that true? Is pause=stop ?
yes, there isn't a way to "stop" the music, it will pause it, and the app will be dormant after a while that you don't use it.
thanks for your help
Anytime, don't forget to try Google Music and here is a sneak peek of what's to come
http://talk.sonymobile.com/thread/38259
