i used to play games on GB n theres nothing wrong all going smooth, but after using ICS i cant play it. eg: asphalt6 or street fighter 4 (after a moment it FC, it has weird graphic or artifact) is there anyway to fix it?
playing temple run, fruitninja HD is actually very smooth... i just updated mine in ICS through ftf file provided uliwooly...maybe try to reflash it wipe data dalvik cache.. wipe everything and dont restore old file maybe thats the problem
What's your phone model? Active? And could you tell what's with your video recording? Is it smooth when you recording? Mine is not. ((( I installed GB, not im gonna try what u said.
http://www.youtube.com/watch?v=UR_tlLE3F8M&feature=youtu.be
but it's in GB rom, it's impossible to play it with current ICS
yes my phone was xperia active... ST17a... i can say video recording was great and smooth... you did not wipe data a cache when you update your phone?
what game is this ant??
yes, i did wipe my data cache. By Flashtool
did you reflash it already?
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
also how to downgrade
yes, i did, still lagging and warming((( Down to GB, and gonna try to install http://forum.xda-developers.com/showthread.php?t=1520456 Have no idea how to do it))) Lot to read.
use this software
the easiest way to upgrade/downgrade, install custom rom/kernel, tweak.
the software will download the necesary firmware for you if available
