Hi, in app OI file manager, i can view the fiiles in LOST DIR folder in my SD card. Most of it are pictures, but, when selecting a file, it seems that its broken or somethinmg else, I just can see the thumbnail profile.
Question, can or ist it ok to delete all these files? I assume i can free a lot of space after doing it so.
please advise, thanks
Hi, you can safely deleted files in the LOST.DIR folder.
(Note: Do not delete the folder, only the files within)
thanks sir
No problem ....
