Managing contacts and SMS messages through PC
Not applicable
I am thinking of getting a Xperia X10 mini/pro handset to replace my nokia phone. With my Nokia I could do things like add and remove contacts through the pc (Running windows xp) and also view edit and delete SMS messages through the PC what I was wondering is what is the software (free) that I would need to download for the Xperia X10 mini/pro ? only I couldnt find it on the SE website. Many thanks, andy.
Er_Kannan
Contributor
You can do it by using software named MyPhoneExplorer (free software). Download the software from http://www.fjsoft.at/en/
You have to install supporting software from the Android market. Search with the term  MyPhoneExplorer in the market to download the application.
1 REPLY 1
Er_Kannan
Contributor
