Manual vs Automatic actualization
Not applicable
Does it have any difference between then?
I mean, It's better to wait for Sony to launch my SI number and update by PCC or to download the ICS version and doing the manual, like that:
http://talk.sonymobile.com/thread/35239
Also, my cellphone is actually MT15a, and for what I've seen this att turns it to MT15i. I live in Brazil and for what I saw the frequency here is 2100 mhz. Probably it's not a problem, but just in case...
I have a XPERIA Neo, SI 1247-1256.
Uliwooly
this is what you could do
backup your current firmware -> manually update to ICS -> once your SI number its on the list -> flashback to your original firmware and use SUS to update
2 REPLIES 2
Uliwooly
Uliwooly
you can read all about it here
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
oh and by the way even if you have the "a" variant you can use the "i" variant, it WON'T affect your 2G and/or 3G connectivity the only difference is that if you go to settings -> about phone the name of the phone will have an i instead of an a, but if you flashback you should get the a back
