Neo v ...4.1.A.0.562 update.. failed!!
Not applicable
hi ,
     pls help me
     during 4.1.A.0.562 update..
     the pc companion have downloaded the update..but during 'preparing update installation' it show error message..like
     "installation or smart phone update failed'
note:
1)sd card free memory 1.8 gb.
2)phone memory free 310mb
3)battery level 84%
pls help me i need ics update in my cute phone...please:(
Uliwooly
Don't forget to backup
http://talk.sonymobile.com/thread/36355
15 REPLIES 15
Uliwooly
Uliwooly
Not applicable
thanks uliwooly, i just downloaded sus..pls wait i will try this..
Uliwooly
ok, let me know if it works
Not applicable
how long ,i should press back key button..while pluging usb
Uliwooly
it shouldn't take that long, make sure that you restarted your PC after installing SUS
Not applicable
awsome dude..it works fine..thank you soo much ,Wooly:)
Uliwooly
anytime
bZed
is sus  better than pc companion,cause even for mine the update failed...i just installed sus nd i'll try...
