My question is, what kind of video file does this phone supports? as I converted some MKV files to AVI and then MP4 and change the screen size to 854 x 480, and uploaded it to phone but the phone displays " Sorry this video can't be played" How it is possible? Help me out Guyz...
neo V supports almost every format of video, but the sony player supports only a few. Download MX video player (free) from Android market, it plays all formats: MKV, H264, H263, AVI, MP4.FLV etc.
Both the people above me have the right idea; you can also try Mobo Player as I have not found a format I cannot play yet. However there is also the white paper for the phone which outlines the default supported formats:
What are your thoughts about this forum? Let us know by doing this short survey.
Thanks Dear I just download the MX player and it plays the converted files... Take care... God Bless You...
Thanks Dude for the help...
you dont even have to convert any video format
just use the player suggested above to play any files..
Thanks Dear...
try BS player lite.
it can play any video n better thn mx.
install it.
then ur phone will play the all video (>~720p) that u play in ur PC.
to transfer the video file, use memory card reader.
