I had updated the android firmware of my song neo v, from Ginger bread to ICS 4.0.3, after this update, im mobile has become lil bit slow, also in most of the applications, I have to face the problem, to WAIT... CLOSE etc.
Also the bad problem which just now i have noticed is that, after 30 seconds, my cell phone's screen is getting of, but right after few seconds, its automaticaly turning on for few seconds, and its happening contineously.
Is there any update after this update , if yes i have checked it in my mobile phone, i have a wifi connectivity, but it says NO new update.
Please help me in this regard.
Nadeem
can you elaborate on SUS? and if it's not on the list you have to wait until it is.
repair it with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://talk.sonymobile.com/thread/36355
And 4.0.4 fixed this wifi and network connectivy issues
if you don't want to wait to get 4.0.4
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
SUS is not going forward after 1st step, i followed to press and hold the BACK KEY but nothing is happening. i have just checked the SI no. on the SONY website, mine is not mentioned :smileyconfused:.
what may i do ... help me please
Nadeem
Repair is available, but i think through repair my issues may not be resolved. Im looking for 4.0.4 but my SI is not yet mentioned!
how sad! why SONY is adding every SI slowly slowly!!!
Nadeem
There are hundreds of variants per Xperia model, so it takes time to get certified and approved. if your phone it's locked to a network then it's up to your network to release it.
