Recently jelly bean update of xperia p has been released.sony mobile can you please give rooting procedure of xperia p updated to jelly bean 4.1.2
There is still not an easy way to root Xperia P running Jelly Bean. You can find various methods on xda developers, but I don't recommend using them. I would just wait for an easy root method to come out. However, if you want to get into all that kind of trouble with the current rooting methods, it's your choice.
Regards.
if ue past ur warranty and have an unlocked BL then just flash any custom kernel to obtain root.
hi http://forum.xda-developers.com/showthread.php?t=2335992 this is wat all the xperia p users where waiting for it .. go here and do as it stated.. ull get root access:smileylove:.. i got it
but make sure it works on the latest .100 update ... :smileygrin:
would you help me pls?
echo You will now get a shell. Enter the following commands:
echo cd /data/local/tmp
echo chmod 777 doomed
echo ./doomed
echo ---------------------------------------------------------------
what can i have to do??
first enter : cd/data/local/tmp
next enter : chmod 777 doomed
lastly enter : ./doomed
then your doomed. LOL. XD
nah, just kidding. thats what i did when im rooting. it went well. try it.
tried ??? rooted ???
Hi kalog,
I tried the steps tat u mentioned and this is wat happened.
The system cannot find the path specified.
I tried in command prompt (I didnt know where to go). Can you tell me how to start and where to do this ?
first enable usb debugging mode, then enable unknown sources from security, now download the v14 version from the link and unzip it .. now click on runme.bat file then the procedure starts in cmd .. there it asks to type some three lines type it and you are done !!
