Sony Ericsson elm j10i2 internet connection problem.
Not applicable
Hi!. i have a problem with my j10i2 phone.I connect the phone to my home wifi (succesful)and then try to log in to my mail adrress for example (but i get the same error on other sites when i try to log in as well) i get this message "Communication failure.Secure connection failed" and i don't know what to do .pls help!
Johan
Master
It sounds like the phone has problems to establish a SSL connection. Try to log in to your services using mobile networks instead of Wi-Fi. See if it makes any difference.
If not, try using the browser Opera mini instead. See if you can log in using that browser.
14 REPLIES 14
Dr_Chris
Champion
Try this: Main menu--Settings--Connectivity--Internet and Streaming settings--Allow Local conn--YES.
Not applicable
Thank you but it seems the yes option was already selected so is not that.
Jake-SonyXperia
Champion
Does this happen to all websites you are trying to access? does the homepage load and can it be navigated through?
Let me know.
Not applicable
Yes this happens to all the sites i'm trying to acces, and yes the pages load and i can navigate through them.the problem appears only when i try to log in to my accounts.
Johan
Master
Not applicable
Thank you!. i' ve installed opera mini and now it works just fine.
Jake-SonyXperia
Champion
Thats great news :smileygrin:
Not applicable
Hey!
I have the same problem. Since yesterday i cant connect to https sites, it tells me secure connection failed. Also with Opera. Works fine on wifi, but not with gprs or g3 or whatnot. the service provider says that they havent changed anything, and my friends phones work fine with the same service.
My phone is J20i.
i have tried resetting and installing certificates, nothing works, please help.
Thank you
K
Not applicable
I have a phone j10i2. I want the phone to the Internet with my computer. It did for me: I did install the hardware and connect the USB cable. And bridge network in my created. And the phone: Menu - settings - Connectivity - USB - Advanced - Internet access - via computer Connection is established. But I sent the computer. I do not see the mobile receiver. The phone to my computer's Internet connection is not.
What do I?:smileyhappy:
[email protected]
Message was edited by: adiuokh
