Sony WF1000-XM4 Earbuds
Bluey2021
I have a pair of XM4 earbuds and use them through the Sony Connect app on my iPhone.
If I purchased a second pair of XM4’s, could they still be assigned to the app and be adjusted and set up as totally separate units to my original pair.
Thank you.
5 REPLIES 5
HannahEd01
Hi Bluey2021, that should be done normally yes.
Bluey2021
Thank you.
SkyNet404
Specialist
Yea and the app will be able to show you which headset is connected at the point, while saving the pairing information for both devices. Actually you can save the pairing information for multiple Sony headphones/earphones ''even if they're different models'' If they're supported by the app, and switch between them based on the current unit connected to it.
Bluey2021
Thank you for that very useful information.
SkyNet404
Specialist
Anytime buddy! Always glad to help ^_^.
