strange led acro s
nonojojo7707
strange led acro s
Please help me
I used my mobile under sea to capture pic and video and after I finished the didn't respond to charger and always give me yellow led and icant open the phone
how can I fix
Uliwooly
flaps is what cover the usb port, SIM/SD cards, 3.5mm jack. Your phone got wet, what you have to do now is
1) open all the flaps and remove the SD and SIM cards
2) place your phone on a bowl of rice
3) let it dry out for 1 or 2 days
Warranty doesn't cover this, unless there's something wrong with the flaps/water seals. you could take it to a Sony repair center and request a vacuum test.
Don't forget to give Kudos
10 REPLIES 10
Uliwooly
You have to check the water damage indicators, in the Xperia Z are inside each flap, I'm not sure about this phone, this indicators are white rectangle, if they get in contact with water they will turn pink or red.
nonojojo7707
That's exactly what happen with my phone , the led get red and pink , so what do you mean by (each flap) I can not reach the mean of it
thanks for your concern but please tell me if the phone can be fixed
Uliwooly
nonojojo7707
i get this problem one week ago and i left the phone two day trying to open it with out any response and after that one of my freinds told me about the rice and i accept his advise and left my phone in the rice for 12 hours without removing my sim or memory card and the phone get started for the first time but with errors such as can not apply charge so after that i put the phone (was switched on) again in the rice wihle i charging it for another 6 hours and also witout removing the sim or memory car .
and after that the phone didnt respond to any thing even to get open
any way after your advise i removed the sim any the memory and put the phone again in rice and i will tell you what happen after
but do you think it will work after all this?
thank you very much
Uliwooly
Check this out, its a similar situation
http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/Warranty-Issue-with-Sony-Xperia-Z/td-p/367526/page/2
Sony Xperia Support
Sam
Re: Warranty Issue with Sony Xperia Z‏
Please be aware that the notification about the flap is not tied to any sensor for the flaps themselves and if select a certain option when this displays the message will not display again. The vacuum test Uliwooly has mentioned is a way for the repair agent to test if there is any fault with the seals or tabs that could have made the handset more susceptible to damage, if it has passed this test then the only way for water to get in would be for one of the tabs to not be closed correctly when it was exposed to water.
What are your thoughts about this forum? Let us know by doing this short survey.
nonojojo7707
Dear sir ,
first : I am sure 100 % I was closing the phone flaps correctly .
Second : I left my phone in blow of rice as you told me and I have just tried  it now but unfortunately it doesn't work properly
I got a new message from the phone (the phone will shutdown due to high temperature)
and the phone shut down
any advise for this message ?
Sam
Legend
Legend
It sounds like there is some severe internal damage if the handset is overheating like that. I can only advise that you cease  using/charing the handset and contact your local Xperia Care team so that they may assist you in getting the handset assessed by an authorised repair agent.
nonojojo7707
I am going to the agency tomorrow
thanks and ill till you what they do after
nonojojo7707
Good morning sir ,
I waked up today and try my phone and I found that it works alright perfect except the over high temperature
I got battery widget on the phone , it gives me really high temperature reach 65 c , before my problem the maxi temp I reach was 46 c , then it shut down . So your advice works successful but I just need another advise for my current error .
Thank you very much
