- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Dear friends,
i have sony ericsson Xperia X10,suddenly i lost all my contacs!!!
any way to restore my conatacs please help??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You may have accidentally filtered them, try the following,
Menu > PhoneeBook > look at the top left hand corner you will see a picture of three heads > Tap on this and make sure Online Contacts has been unticked.
If that does not resolve the issue simply go through this section and find the right combination to bring the contacts back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
do you have android 2.3 or 2.1?
open your contacts -> press menu -> import -> from internal memory/sd card
Don't forget to mark the Correct & Helpful Answers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on your computer go to your gmail
click on the left side where it says Gmail -> there should be a dropdown menu -> select contacts are your contacts there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
if you previously backed up your contacts with the Backup & Restore app just run it and then select only contacts to be restored
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks a lot,my contacts were filtered accidently
thanks GOD
and really thanks 4 ur support and rapied answear
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
anytime
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
sorry Guys I have another problems, i tried to restore my contacts by using backup contacts and all my numbers are repeated four times,how to mange ???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
go to phonebook -> menu -> filter and select only ONE option like phone contacts or google etc just one
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi, i lost all my contacts on xperia m4 aqua.
tried to follow some of your previous advice and found contacts attached to my gmail but unsure how to transfer them over. Can i transfer quickly or do i have to do manually
