Hi there
Before the latest update, one would get the possibility to switch between recent/open apps when pressing the home button for a bit longer. Now this action only brings up the google search function. Is there any other way the switching-option is accessible now after the update?
thanks for your help
ah wow, could have tried that
thank you
That's ok my friend,do not forget to give kudos.
It is the only way...
