Which is the smallest Xperia phone?
pamelap
I have always bought the compact version of Xperia phones, at present having XZ1 Compact.
My battery is running down very fast, needing two full charges a day. As I can't fit a new battery looks like I have to buy a new phone (annoying).
There are no Compact Sony phones any more so I am wondering which is the smallest, lightest Sony phone reasonably recently released, currently available?
Elan_G
Hello there!
Thank you for your question regarding the size comparison of Sony phones. If you follow the link below, it will take you to a handy comparison page. You can scroll down to the size/dimensions and see which best suits you there. I hope this helps!
https://www.sony.co.uk/smartphones/compare?cpint=gwx-all-smartphones
1 REPLY 1
Elan_G
Hello there!
