Hello
i have a little problem with my x10 mini pro (android 2.1) ....
When i go to menu > wirelles&settings> wifi settings it shows unable to scan for networks
... pliz someone help me plizzz....
don't worry about your English as long as we understand what you say that's good enough
try to repair it with SUS
http://www.sonymobile.com/gb/tools/update-service/
restart your phone and check again
it don't helped
have you got any ideas else? (sorry about my english i am from latvia )
tnx i will try it
Let us know if it work
ok sevice is installing now on my pc
Thank you uliwooly it works
you are great men
big big big tnx
you really helped me
tnx again
