XAV-AX8050D
Katkoh1
XAV-AX8050D
Hello!
Please may I request help with an odd issue.
I have the above head unit installed in a 2015 Jeep Wrangler JKU. It was installed by a reputable installer in London.
Recently, I have been losing the ability to use the steering controls. So I have to program the buttons every time I use the vehicle.
I've done some research online, it could possibly be the clock spring in the steering wheel which I will change regardless. Last resort, it could be a loose wire at the back of the unit, poss from a rough ride jolting the harness, but would be a long shot.
If anyone has any ideas about this issue, I would much appreciate any input.
Thank you.
1 REPLY 1
Elodin
Hey, before doing that, trying checking if your device is running on the latest software version from this link then test it, if it is still the same, then try to restore factory settings, from this link. I hope this helps.
