we all know that when we Drag the status bar downwards
in all android phones (Notification panel)
we find the bluetooth wifi and sound
my xperia acro s there is no any of this only the settings and update available
can any one tell me what can i do !
thanks
this mean i can update to JB without any problem or what 😕
Which android version do you have?
Settings > about phone
android 4.0.4
Do you have a Custom ROM? or Do you have a different home launcher?
i dont know ! cause this the first android phone i use !
the phone owner travelled and let it to me ! how to know if it custom ROM ?
no its not a different home launcher
what wil happen ! after that update ! will OS be JB ! and the problem will be fixed !
sorry of my english
what is that repair or update
it will be Jelly Bean if the update is available in your country/market/region
thank you very very much for your replies
Sorry for the large number of my questions
i have last question hope you will reply if my phone run custom ROM !
will it be able to update or wont Knowing that i notified that an update available 6.2.B.0.211
finally thanks
