im from chennai,tn,india; have a black xperia arc s which has a slight dent in the front panel,, so i am thinking of replacing the full housing but with a white housing. is that possible and whom should i contact??
http://www.sonymobile.com/global-en/support/contact-us/
Local support team should be able to help you
