In my phone (Xperia P) Clock is not updating when screen is off. What can I do? (Application for battery -Go Power Master) For more details screen shot is attched with here.
Try not to use battery save apps,they could keep the system behind.
Yes,when it is locked with a password or pin or pattern,the clock updates a little slower(it is UI bug also).Are you using a lock on your phone?
Thanks. After uninstall battery app problem solved.:smileyhappy:
Anytime!
battery saving apps stop the processes running in background, it probably stopped the clock process
