My question is on this link http://talk.sonymobile.com/message/188653#188653
Why my antenna (below the transparant line) not perfect stick like, in this problem not the same as before. The antenna sway more severe than first I make thread above
My Xperia never crashed...
Does this matter fit into warranty ?
if the antenna seems loos or the bottom cap take it to a sony service center
Anyone can help me ?
If I use the warranty on the Sony Service Center, whether the charge ?
I don't see why will they charge you, if it's a factory issue it should be cover by the warranty
Ok uliwooly
let us know how it goes
