Hello, I am using sony xperia tx and the phone is awesome i just love it but there is a problem in my display. I noticed couple of day after purchasing this phone that there is some dots on my display (some are green some are red) and it's visible when the display backlight is on and also those dots can be notice if playing movies and in any dark pictures.
I've the original screen protector on my display. So is there anything i can do to solve this display problem? Also i wanted to know that is the camera glass scratch resistant or not? If not what can i do to protect the camera glass?
Please help me for this issue ASAP.
Thank You
Faisal Amin
Glad to hear that you like your phone
It sounds like you have stuck pixels in the display. Sometimes a pixel in an LCD gets stuck and will always display a certain colour like green, red or blue. In general, 1-2 stuck or black pixels are considered acceptable and not a fault in the phone. Depending on how many you have you can however get the display replaced under warranty. Please check the warranty documentation for your country here: http://www.sonymobile.com/global-en/support/phones/xperia-tx/support-documents/.
The camera is scratch resistant but i would avoid keeping the phone together with sharp objects like keys, coins and so on.
Thank you so much. I don't have warranty for my phone however i'll replace the display from sony service center with my own cost.
