Yellow Point on Display
Not applicable
Hi, I just bought an Xperia S over ebay (cuz it's so expensive) and I saw that I have an Yellow Point on my Display (like 2cm over the transparent bar) and I wanted to know if I can do anything about this... It's my first Smartphone ever so I don't rly know how it all works.. Dizzy_Face
Thank you in advance
My SI is: 1257-2735 (don't know if it's relevant)
-freakyone98 (from Germany)
Uliwooly
This is a hardware issue and you need to take it to a Sony Repair Center
3 REPLIES 3
Uliwooly
Not applicable
Alright, thank you for the quick reply Slightly_smiling_Face
How can I find an Sony Repair Center? Is there a search option on the Website? I didn't see one...
Uliwooly
http://www.sonymobile.com/global-en/support/contact-us/
