Skrzetu
3D
Does TMR-BR100 (3D transmitter) work with TDG-BR750 (3D glasses)?
3 REPLIES 3
profile.country.en_GB.title
Catmambo
Contributor
Yes, should do..
Skrzetu
for sure?
Anonymous
Not applicable
HI there
According to this manual : Here
The 3D transmitter works on Infrared (IR) signal
According to the TDG-BR750 manual : Here
The 3D glasses receive an IR signal from a transmitter
So both work in conjunction with each-other - A sender and a receiver.  If you purchase a product over the internet you have a 7 day long distance selling legislation.
Hopefully that helps you
Cheers.
